Author Topic: Wobble Bolts...  (Read 2075 times)
Offline Sam
  • Sam I am
Wobble Bolts...
« on: 26 December 2011, 12:14 »
Whats peoples opinions on them, ok for a daily hack? Are they safe? Say taking 5 x 112 to 114.3
Re: Wobble Bolts...
« Reply #1 on: 26 December 2011, 14:04 »
I know loads of people with them, no issues at all, I would say they are safer than adaptors.
Offline i_am_me
Re: Wobble Bolts...
« Reply #2 on: 27 December 2011, 20:39 »
i run them on my golf and ive never had a problem with them,never came loose or stretched and dont get any wheel wobble :cool:
but they are only designed for 2mm of difference so you would be pushing it on those sizes.
<br />
If at first you don't succeed skydiving is not for you
Offline Sam
  • Sam I am
Re: Wobble Bolts...
« Reply #3 on: 28 December 2011, 12:06 »
Yer 2 mm per bolt though isn't it? Meaning that they allow for a 4mm difference in total in pcd
Offline tweed
Re: Wobble Bolts...
« Reply #4 on: 28 December 2011, 18:31 »
No! The 5x112 etc is from the centre bore to centre bolt hole. So each bolt would have to go 2.3
Offline danny_p
Re: Wobble Bolts...
« Reply #5 on: 28 December 2011, 18:51 »
Quote
The term PCD stands for (pitch circle diameter) and is the diameter of a circle drawn through the centre of your wheels bolt holes. PCD is measured in millimetres and also indicates the number of studs or bolts the wheel will have.
all the VW's have gone bar 1.
Re: Wobble Bolts...
« Reply #6 on: 28 December 2011, 19:27 »
Don't think so I believe they allow a max 2mm adjustment in total so 4x98 to 4x100 etc.
Offline justalex81
Re: Wobble Bolts...
« Reply #7 on: 28 December 2011, 21:29 »
it's 2mm total.
Offline lewis1641
  • stuck in the 90's
Re: Wobble Bolts...
« Reply #8 on: 30 December 2011, 09:47 »
def 2mm total sam but i have seen plenty of jap wheels on mercs and audis so i suspect they are bending them slightly!
have a look towards the vauxhall end they are 110 although centre bore is usually small unless aftermarket i suppose)
