Author Topic: gearbox help 02j  (Read 1915 times)
Offline stealth_gti
gearbox help 02j
« on: 24 December 2011, 16:32 »
merry christmas chaps,
im picking up my mk2 gti next week and have already dropped engine and box out of my mk4 1.8t agu.
my job for jan is to do the conversion, but i would like to keep the mk4 box 02j i no this is possible but does anyone no a in depth parts list id need and a guide to do it.
all help would be appreciated
cheers Scott
2** Bhp, 2** Lb/ft , R-Tech map, FMIC, Forge CL007P, Powerflow Cat-back, 18" Tsw pace, Eibach -40mm springs, Pipercross induction kit, vr6 Clutch g60 flywheel
Offline Diamond Hell
  • Opinions я Us
Re: gearbox help 02j
« Reply #1 on: 24 December 2011, 17:05 »
Should be fine, although you'll need to sort out something to drive the speedo electronically as IIRC the 02J has no speedo drive.
Is the unit you have 5 or 6 speed?  If it's only 5-speed an 02A would be fine instead - definitely has the mechanical speedo drive on it.
Make sure you have the mounting lugs on the 02J as well - there should be a pair of bolt holes on top of the unit at the end furthest from the engine.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 24 December 2011, 18:15 »
i didnt think the o2j was a straight bolt up thought that was only the o2a ??
  • Opinions я Us
« Reply #3 on: 24 December 2011, 19:56 »
I don't think there's any bolt-pattern difference, but you need to make sure there are the mounts for the Golf2/3 type mounts as well as pendulum (Golf4 type) mounts.
Offline danny_p
« Reply #4 on: 24 December 2011, 20:56 »
adaptor mount arm to bolt a pendulum mount box upto mk2/3 mounts is basic fabrication
all the VW's have gone bar 1.
