Author Topic: changing breather pipes to silicone ones.  (Read 2027 times)
Offline 01664gti
  • mk3 hatch mk3 wagon and mk2 16v
« on: 24 December 2011, 11:48 »
My breather pipes on the inlet manifold etc are really fraid and scruffy,I replaced the ones on my 8v with siilcone ones but i cannot remember which size or internal diameter i bought.
Ill probably just buy it by the meter as i need to do 2 engines
Do any of you legends know what size it is??
« Last Edit: 24 December 2011, 13:38 by 01664gti »
Offline Sam
  • Sam I am
Re: Please delete sorted now
« Reply #1 on: 24 December 2011, 12:49 »
Hey buddy, instead of deleting the thread could you post the info you have found. These sections are all about creating a catalogue of solutions/info that you can simply use the 'search' funtion to sieve through. So if you could change the title back to something appropriate to do with the topic then put your info up as a final post that would be great.  :smiley:
Offline 01664gti
Re: changing breather pipes to silicone ones.
« Reply #2 on: 24 December 2011, 13:40 »
Here you go mate
Its 7mm with 3mm id(internal diameter),I just looked through my feedback and found the stuff i had before.
http://www.ebay.co.uk/itm/Silicone-Vacuum-Hose-Pipe-Silicon-Air-Water-Washer-Turbo-Dump-Valve-Radiator-Vac-/140651602472?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item66740ef761
