Author Topic: Interior light question?  (Read 1471 times)
Offline gti_boz
« on: 23 December 2011, 19:12 »
Right... When you open the pass side door the interior lights or the puddle light don't come on.. Iv had the door card off.. And when you touch the little resister thing on the puddle light on to the metal of the door the interior lights come on so does the puddle light..
Can anyone help any ideas?
Iv tried a different lock module, puddle light and a door loom and still no luck
Cheers :)
Offline Ninja
  • 19 smiles per gallon
Re: Interior light question?
« Reply #1 on: 23 December 2011, 19:14 »
Same issue here - both doors!  :cry:
Offline Mike671
« Reply #2 on: 24 December 2011, 10:30 »
Well most lights are switched earth so check micro switch in door lock is working correctly if not get your wiring diagrams out and check earths for shorts high resistance or an open circuit
Esplanade V.W Audi Mercedes And Smart Tech
Offline Dizzie
  • Make friends with your fast
« Reply #3 on: 24 December 2011, 12:09 »
I'm not sure what you mean by the little resistor thing on the door, but I had this problem with my drivers door which led me to leave my lights on a few times as the buzzer didn't sound.
I stripped the door down and removed the lock assembly. It turned out the solder joints on the circuit board had gone dry. Once re-soldered and reassembled everything works perfectly.
Mk4 Golf 150PD
Offline gti_boz
« Reply #4 on: 24 December 2011, 15:39 »
That's what i thought it might be so I just brought another.. Unless I'm really unlucky and both have gone.. And there's a little resister on the top of the puddle light.. I'm going to try the earths then if it's not that it must be the lock assembly..
Cheers so far :)
Offline johnomk4
« Reply #5 on: 24 December 2011, 17:22 »
I had the same problem, it turned out to be the door moduel. Change it and it should work then.  :smiley:
Offline AD1.8T
« Reply #6 on: 24 December 2011, 18:42 »
Same problem !! Is the switch the best place to start ? Also my rear passenger light doesnt work at all i got it to after fiddling now its stopped again ??
Offline gti_boz
« Reply #7 on: 24 December 2011, 20:33 »
So the door lock module? Iv replaced it once.. It was second hand though.. He said it worked but suppose that dusnt mean it does..
Offline Mike671
« Reply #8 on: 24 December 2011, 20:54 »
It's normally the micro switch in there that fails or circuit board connecting to it you can check on bag com mvb's to check for door open/door closed positions
danielo
« Reply #9 on: 02 February 2012, 12:23 »
Yeah that's what I did too and it worked fine.
