Author Topic: rcd 510  (Read 1916 times)
Offline mossy1969
rcd 510
« on: 23 December 2011, 16:19 »
hi there just wondering if my 2005 gti will need a canbus upgrade for the rcd 510 its not the sat nav unit just the cd player,,,cheers,,i will be changing it form a rcd 300
Offline crimsonfin
Re: rcd 510
« Reply #1 on: 23 December 2011, 19:27 »
yup sure will
i installed one into my 06 GTI and it worked fine but drained the battery completely over a period of about 4 days (there is some incompatability issue which means it draws a current even when switched off).  it came out and an RCD 500 went in as I couldn't be arsed with the extra expense and hassle of the canbus upgrade.
Offline swanny
Re: rcd 510
« Reply #2 on: 27 December 2011, 10:46 »
I did this and ran in to many problems. You first need an adaptor cable (Ebay £20) so the cables will fit.
Then you have the power drain problem. I am using a JOSI version (2720) which does not have power drain issues
If you have MFSW you will need to turn BAP on for all of them to work
Worth the hassle in the long run as I am very happy now......
Good luck....
Offline mossy1969
Re: rcd 510
« Reply #3 on: 28 December 2011, 04:29 »
hi there just wondering who upgraded your canbus and was it reasonable price wise ,,,many thanks
Offline kalpsn2000
Re: rcd 510
« Reply #4 on: 29 December 2011, 00:16 »
I went from the RCD500 to the RNS510 in my 56 plate and I had to change the canbus. The guy I bought the RNS510 off changed my canbus for me (I had bought the canbus of the bay for about £60).
Also if you remove the plastic connectors from the aerials you dont need the adaptor.
I have to say the upgrade is well worth it, brilliant bit of kit.
New: White Mk7.5 GTI (Standard...for now :smiley:)
Gone but not forgotten:
Diamond Black 2007 (56) Golf GTI 3Dr DSG ¦ 18" Monza II's ¦ Cruise control ¦ MFSW with Paddles ¦ Highline ¦ Rear parking sensors ¦ RCD500 to RNS510 C LED to Kenwood DNX521DAB ¦ Lowered on H&R springs ¦ R32 Rear bumper ¦ BCS Powervalve Sports R32 style TBE ¦ LED Rear Lights ¦ PDT Stage 1 ¦ NQSBBK ¦ 12mm Spacers ¦
