Author Topic: WHAT SPRING IS THIS?  (Read 1166 times)
Offline faigolfgti
« on: 12 May 2005, 11:27 »
Recently i bid a pair of coil spring from ebay according to the seller it was from koni sport pack,but the spring don't have any KONI word only number for the front 98406 and rear 09406 both in red color hope the member in this forum can assist to check out the spring is from which compay.Thank You.
Offline animaniac
Re: WHAT SPRING IS THIS?
« Reply #1 on: 12 May 2005, 15:30 »
koni ones are painted blue!!
i've checked on koni.com..
and the numbers dont match! so i dont know wether or not they are the correct ones!
i soppose the only thing is take the ones of the car and compare them to theses ''konis''
they will be smaller springs but they should fit the same!
you could try emailing koni...
