Author Topic: Get ready for another silly question....  (Read 4272 times)
Offline sKrEwBaLL
« on: 23 September 2003, 15:22 »
How do you set the time on the MFA..?
Offline Gambit
Re:Get ready for another silly question....
« Reply #1 on: 23 September 2003, 15:44 »
have a look at this pic
http://homepages.manx.net/homepages/business-services/16%20valve-5.jpg
you see the two little holes in the perspex either side of the mfa? well if yours are like this then they are broke & there is no way of setting the time
only way is to disconnet the battery at 12 midnight, then reconnect it
though this can sometimes spike the MFA into now working at all, especially if they are motometer twin plug clocks found on pre89 gti's
Offline pipworks
« Reply #2 on: 23 September 2003, 17:33 »
Mine look like that? So are mine broke then? Has anyone got a picture of what they should look like?
I just shove a pen in the holes there, press hard and it alters the time??
Mine don't look broke ???
Offline sKrEwBaLL
« Reply #3 on: 23 September 2003, 18:30 »
I'll try the pen thing
golfvr6
« Reply #4 on: 23 September 2003, 18:43 »
Its a know fault for the clocks to go funny on  the various VW models, transporters and Mk2 golfs always have this problem.
Expensive I fix I hear and a darn site cheaper to wear a wristwitch.
Offline modulater
« Reply #5 on: 23 September 2003, 20:52 »
Mines gone funny and wont for love nor money adjust the time on the clock, luckily the MFA and speedo still work.
Offline Harooshum
« Reply #6 on: 24 September 2003, 12:03 »
Mine cocked up a bit, and instead of disconnecting the battery, just remove the 2nd fuse in from the right, which disconnects the MFA, interior lighting etc. (On 16v, 8v is fuse is on the leftside of fusebox)
You may need to push quite hard for the digits to move, so be patient.
H.
Offline Gambit
« Reply #7 on: 24 September 2003, 12:07 »
hmmm, i shall have to try this at lunch
if i find out its been working all along ill crack!!
Offline Ant
« Reply #8 on: 24 September 2003, 15:51 »
Mine thingyed up a bit, and instead of disconnecting the battery, just remove the 2nd fuse in from the right, which disconnects the MFA, interior lighting etc. (On 16v, 8v is fuse is on the leftside of fusebox)
This worked for me, however it was the third fuse from the left. 1989 on a G plate.
Haynes identifies that this is the new fuse layout from Aug 1989 - Feb 1992.
When you've pulled the fuse the MFA should go out, so you'll know you've got it.
Offline Gambit
« Reply #9 on: 24 September 2003, 16:06 »
yep, pushed the pen in & hey priesto MFA time is now correct
