Author Topic: Electrical question *see link*  (Read 1631 times)
Offline Dave_IOW
« on: 21 December 2011, 19:49 »
Hi, i have no idea about electronics or there ratings to be honest.
I am looking to use this switch in a methanol injection take and would like to know if it will run off 12v from the car.
http://www.ebay.co.uk/itm/Tank-Water-Level-Sensor-Liquid-Float-Switch-Horizontal-Black-/290637902507?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item43ab5e72ab#ht_2044wt_1185
Much obliged  :afro:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Bellend
Re: Electrical question *see link*
« Reply #1 on: 21 December 2011, 21:19 »
I reckon so yeah. It's only a switch.
Where all my moneys went.
Offline smiley125
« Reply #2 on: 21 December 2011, 23:47 »
Perfect as-long as you aren't switching a big load with it :)..
Offline DOA
« Reply #3 on: 23 December 2011, 13:49 »
Itll be fine but if you want some protection/piece of mind, use the switch and relay setup with the motor side on a fused supply and a suitably rated relay to take the current. Just bear in mind that you wont get much travel out of that switch so it might be better mounting it the opposite way up at the bottom of the tank, otherwise it may end up either intermittently cutting your supply out or just being useless. Also bear in mind that a tall tank with a relatively small plan view area (ie, like a 2l coke bottle but not a 2l coke bottle or it wont last long with methanol lol) will stop your fluid sloshing around as much, preventing the switch from being overactive.
Offline Dave_IOW
« Reply #4 on: 23 December 2011, 21:00 »
It will be going din a 4 litre tank, mounted in the boot. My wiring skills are limited and although i almost understand, relays i dont get atall.
