Author Topic: Coil Packs & Misfire & Recalls  (Read 1745 times)
Offline dTEA
  • back in an MK5
« on: 20 December 2011, 22:43 »
Well, if in doubt, read the forum, read over at mk5gti.co.uk and then give it a go...thats what I should have done!!  Car was misfiring anywhere in between 1800rpm and 3000rpm.  New spark plugs 18 month ago and then 6 months ago the coil packs were replaced under the recall from VW.
No fault codes were stored so manual check of which cylinder/s werent firing as at first they thought it was the EGR.
I told them to check the coil packs as i had a suspicion after reading on here and mk5gti.co.uk...and low and behold...coil packs and new sparks needed.
So coil pack fails and takes the sparks with it  :angry: But better still, the dealer points out that VW wouldnt replace the parts under warranty as they had replaced them previously, and now count still as 6 month old  :grin:
Ah well, the old gal feels better now and hopefully i'll see more than 220 mile to tank  :shocked:
Edition 30 / T5 T32 Kombi
Offline muttlybaddog
Re: Coil Packs & Misfire & Recalls
« Reply #1 on: 23 October 2012, 21:22 »
Day after car had remap coil pack fault occurred , whilst overtaking the car misfired badly, could only very slightly touch accelerator pedal with our car misfiring. Changed all 4coil packs at a cost of £130 ( euro car parts) and car is now fine, very easy job to do yourself ps engine warning light stayed on so ditched battery for a minute to reset.
Offline FamilyDub
« Reply #2 on: 29 October 2012, 12:21 »
There was a recent workshop action (not a recall) issued by VW to change coil packs FoC.
The code was 28F5.  Ring a VW dealer with your reg/VIN and they'll check if your car is part of the batch affected.
My '06 was affected and changed last summer at a standard service visit.
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
