Author Topic: mk5 golf plus heater fan  (Read 3255 times)
Offline danny_p
« on: 20 December 2011, 20:52 »
interior heater blower is playing up on mothers mk5 golf plus,   it works flat out or not at all.
any common causes for this  i'm guessing theres a resistor pack or pwm drive moduel somewhere thats failed,   or is it built into the motor ?
id rather not take the dash out if dont have to
all the VW's have gone bar 1.
Offline topher
  • Administrator
  • fully functioning
Re: mk5 golf plus heater fan
« Reply #1 on: 20 December 2011, 21:29 »
heater blower resistor, fairly common fault. Not sure where it is on a plus, somewhere under the glovebox at a guess
Offline Mike671
« Reply #2 on: 20 December 2011, 22:49 »
Separate blower resistor as said Danny is same as golf go up under glovebox and remove the foam held up with two hand twist screws and pull cover down you should see it in not glovebox out (as cant remember on golf plus of top of my head)
Esplanade V.W Audi Mercedes And Smart Tech
Offline danny_p
« Reply #3 on: 24 December 2011, 02:00 »
brilliant sounds like an easy fix then  :smiley:
was just dreading the dash out as for some reason i've had a run of dash out jobs
