Author Topic: Golf MK3 - Daily CL  (Read 51284 times)
Offline clancy
Re: Golf MK3 - Daily CL
« Reply #20 on: 28 December 2011, 18:51 »
as above, checl that. are mk3 speedos able to be re-calibrated ?
and as for tyres, difference between the tyre size you posted in your picture and thesehttp://i14.photobucket.com/albums/a321/darkartist1989/Mk3%20Golf/3728742785_61a0ae1abf_o.jpg
granted these alloys might be bigger but that the difference in look it will give you
MK3 GTI 16v
Offline dom
  • Back in a Mk4
« Reply #21 on: 28 December 2011, 18:57 »
The difference between 195 & 205 on a mk3 speedo is negligible. 195's are cheaper and look better, plus I found mine drove better on them.
Some Gti's were fitted with 195s from the factory. It's an all round better choice :wink:
Offline CM690
  • Golf MK4
« Reply #22 on: 28 December 2011, 19:02 »
I don't fancy my speedo being out even if it is only slightly :tongue:
Offline clancy
« Reply #23 on: 28 December 2011, 19:04 »
alloys of that sort of design should always have tyres that are thinner to enfasize there design. and smaller profiles too :)
so 195/ 45 or less is what you want. cheaper tyres too as said above
as for the speedo, what where the original size alloys and tyres ?
MK3 GTI 16v
Offline CM690
  • Golf MK4
« Reply #24 on: 28 December 2011, 19:05 »
Well I currently have 13" steelies with....something small on them. Cant remember off hand.
Offline dom
  • Back in a Mk4
« Reply #25 on: 28 December 2011, 19:09 »
It'll be out anyway, check it against a sat nav. 195/45/15 is a standard tyre size & will not affect the speedo.
Offline clancy
« Reply #26 on: 28 December 2011, 19:09 »
does it have huge chunky profile tyres on it ? if not then anything you put on will put it out lol, difference between 40 & 45 profile on 195s will be nothing in comparison to going from 13s to 15s
do the speedo calculator thing as suggested ( either google it or its a sticky on here somewhere) would of thought the speedo is able to be re calibrated anyway, wouldn't cost much
MK3 GTI 16v
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #27 on: 28 December 2011, 19:11 »
Check the manual for original size and do a comparison on here anything around 3% difference is OK.... http://www.alloywheels.com/Tyre_Calculator
Even changing the width changes the overall rolling size of the wheel... Like most I thought it didn't matter but it does...
« Last Edit: 28 December 2011, 19:17 by X4MGS »
For More Info Click To See;
Offline CM690
  • Golf MK4
« Reply #28 on: 28 December 2011, 19:20 »
I think my original tyre size was this for my 13". If so this doesn't seem so bad?
Offline clancy
« Reply #29 on: 28 December 2011, 19:22 »
mate thats more than fine lol. mines further out than that, if it makes less than 2/3 mph difference then it dont matter at all tbh
MK3 GTI 16v
