Author Topic: Apple TV2 wifi bridge/router  (Read 2366 times)
Offline Guy
« on: 20 December 2011, 12:06 »
is it possible to route the following to get interwebs to sky HD box?
interwebs -----> wifi router -----> apple TV2 wifi connection -----> ethernet out -----> sky box ethernet in
just a thought like as possibly going to get AppleTV2 anyways
Offline Jay
  • balding fat cvnt
Re: Apple TV2 wifi bridge/router
« Reply #1 on: 20 December 2011, 12:15 »
Probably not I'd imagine, unless you Jailbreak it and get console access to muck about with the OS underneath. unless the Jailbreak version can do this already....
Offline Ridg
  • TDI - Soot Happens!
« Reply #2 on: 20 December 2011, 12:20 »
doubt it buy you could
internet====> wifi router====|wifi bridge|==> wifi access point =====> sky
                                  ====|wifi|=======>crappleTV
Offline Guy
« Reply #3 on: 21 December 2011, 11:22 »
going to try this with a time capsule instead (seeing as I already have one in a different location)
surely this must be possible??!!
internet -------> router -------> wifi -------> time capsule -------> ethernet -------> sky hd box
        -------> apple tv2 etc
Offline Ridg
« Reply #4 on: 21 December 2011, 11:32 »
very much doubt it
Just because it's got an Ethernet port, doesn't mean it supports internet connection sharing.
In order for the device to share the connection it needs to be able to act as a gateway, passing through the traffic from one device to another, basically you need a device that can act as a router or gateway, meaning you need either a second wireless router or access point or a PC / apple that supports sharing or a long length of cat5e, I'm guessing you're trying to do it on the cheap but you're gonna need to put your hand in your pocket.
Offline Guy
« Reply #5 on: 21 December 2011, 11:36 »
very much doubt it
you're just saying that to make me try it now aren't you?!  :grin:
page 19 is what set me thinking...
http://manuals.info.apple.com/en/TimeCapsule_SetupGuide.pdf
Offline Horney
« Reply #6 on: 21 December 2011, 11:41 »
Time Capsule is a router, should work fine.
Nick
Offline Ridg
« Reply #7 on: 21 December 2011, 11:53 »
Nick
I thought it was simply a NAS
Offline Horney
« Reply #8 on: 21 December 2011, 12:00 »
Nick
Nope it's a wireless and wired router with a built in HDD.
Nick
Offline Guy
« Reply #9 on: 21 December 2011, 17:51 »
right that would be that problem solved then... I will have a crack at this soon
next issue...
I has a printer plugged in via USB to the Time Machine so that I can print wirelessly and have the printer set-up out of the way
It wouldn't be able to go where the Time Machine will be relocated to so is there any solution for this scenario?
sky router ------> wifi /ethernet -------> usb printer
