Author Topic: Injectors  (Read 1702 times)
Offline siddleg
Injectors
« on: 19 December 2011, 22:23 »
Evening all
my 8v gti on a G plate seems to splutter whilst traveling slowly in traffic its fully serviced with plugs, leads, arm, dizzy, new blue temp and fuel filter etc but its still doing it.
i was thinking of having the injectors ultrasonically cleaned but its over £100 is it worth it or could it be something else?
Offline Bigdunc
Re: Injectors
« Reply #1 on: 19 December 2011, 22:29 »
the mass air flow unit can make them go like that, when myne was going it went juddery, also if you have a highlift cam they can go bit juttery aswell, myne dont like to go to slow untill its warm.
maybe injector seals poss sucking in air??
Re: Injectors
« Reply #2 on: 19 December 2011, 23:46 »
Unplug the maf and see if it runs any better
Offline siddleg
Re: Injectors
« Reply #3 on: 20 December 2011, 19:13 »
where is the maf ?
Offline keg
Re: Injectors
« Reply #4 on: 20 December 2011, 20:04 »
maf is (mass air flow sensor) if you look at the engine look to the air box your see a electrical plug about 2" long thats what you need to unplug
Offline siddleg
Re: Injectors
« Reply #5 on: 20 December 2011, 22:13 »
oh yeah i know what you mean i cleaned the contacts with electrical cleaner the other week, made no difference lol
ill try unplugging it though
cheers
Offline siddleg
Re: Injectors
« Reply #6 on: 21 December 2011, 12:06 »
Pulled off the maf and it wouldn't even run so could it still be that? or injectors?
Offline weazgti
Re: Injectors
« Reply #7 on: 21 December 2011, 13:32 »
it wont run with the maf unplugged.
you checked your breather isnt full of water? my oil cooler jusst went but it was spluttery in traffic and on idle before it went properly.
