Poll
Cold start very poor sounds like it's starving on fuel
Cold start?
1 (100%)
Poor star
0 (0%)
Total Members Voted: 1
Author Topic: Cold start  (Read 2082 times)
Offline Mattb87
Cold start
« on: 19 December 2011, 18:22 »
Hi I'm new on here, I have a 95 golf mk3 gti 8v having problems getting it started when left over night???? Will cough then eventually start but when u rev it sounds like it's not getting fuel afte about 2 mins it will be ok??? Then you can turn off and start again and all is fine? Some1 give me some ideas please????? :angry:
Offline richw911
Re: Cold start
« Reply #1 on: 19 December 2011, 18:32 »
When was it last serviced? Spark plugs in good order?
Offline Mattb87
Re: Cold start
« Reply #2 on: 19 December 2011, 19:03 »
Was serviced 2 months ago, but fuel filter wasnt done? Have had no problems until this really cold weather has hit in, I work nights so drie to work 8 hours of cold weather makes it very hard to start cranks over fine, the oil can light? Flashes with ignition on and takes a while to go out? Would this be anything to do with it? As soon as it does start and I drive 15 foot it's fine runs as normal?
Re: Cold start
« Reply #3 on: 19 December 2011, 23:38 »
Might be worth getting the battery tested.
Offline Mattb87
Re: Cold start
« Reply #4 on: 20 December 2011, 00:30 »
Havnt checked battery, seems to fire over very easy just the actually starting part it doesn't like, when it does idle u can go to rev and it just dies but after 1 min sat on idle all is fine, will check battery and plugs many thanks
Offline javalin
Re: Cold start
« Reply #5 on: 22 December 2011, 21:50 »
changed my battery recently too - car cranked ok, but hard start in the cold and dash would reset due to voltage drop.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline dilbert
Re: Cold start
« Reply #6 on: 24 December 2011, 17:09 »
Think simple 1st. Fuel filter. Plugs. Ht leads  distrubitor cap
mk4 golf 1.8 gti 20v
Offline stow1985
  • 'when im cleaning winders'
Re: Cold start
« Reply #7 on: 31 December 2011, 00:54 »
How about cleaning the Idle speed control valve and throttle body?
