Author Topic: MK3 1.8T  (Read 72965 times)
Offline Ferdinor
Re: MK3 1.8T
« Reply #20 on: 19 December 2011, 14:51 »
Thank you for the great information, i shall be trying to source a very cheap 16v once i have saved up a couple of pay checks, as said in the first post this is gunna be a slow thread (very slow) due to lack of money, but i will try and update everything i do  :smiley:
After everything said i have a much better idea already the only bit i am dreading is doing the wireing myself as i just cant afford £600 for qpeng, i am very good with electronics and so is my dad so hopefully i can do it  :huh:
I really wanted to stick with 4 stud tbh, i have heard the g60 front brakes would be good enough for stock power and the mk2 gti disks on the rear?
The reason i want 4 stud is because i may have a nice set of rims ready to go on when this is done, i guess i could run 5 stud steelies at the start then convert to 4 stud?
I shall be taking some photos later of the engine starting to be striped will be taking the top cover of and the inlet manifold of to start polishing will update late tonight  :smiley:
Thanks for all the help so far
cheers
Offline dom
  • Back in a Mk4
Re: MK3 1.8T
« Reply #21 on: 19 December 2011, 15:41 »
Stick with 4 stud, much better choice of wheels :wink:
Offline Seanl
Re: MK3 1.8T
« Reply #22 on: 19 December 2011, 15:53 »
It's funny that when u hav 5 stud you can't find the wheels you want, so you have to add expensive adaptors into the equasion. Then you go 4 stud, and every set of decent wheels that comes up are friggin 5 stud!  :rolleyes:
Offline SoundillusioN
Re: MK3 1.8T
« Reply #23 on: 19 December 2011, 16:17 »
I think the 4 stud issue happens when you fancy something a little old skool. Lucky for me I don't think there's ever been a 5 stud wheel I've fancied for it.
Offline DanChave
Re: MK3 1.8T
« Reply #24 on: 19 December 2011, 16:19 »
I found that! When I had my Vento 1.8 8v all I the wheels I wanted were 5 stud. Then I got my VR6 and all the wheels I wanted were 4 stud! Then I got my current MK3 and I ended up getting adapters  :laugh:
Re: MK3 1.8T
« Reply #25 on: 19 December 2011, 16:27 »
That's the trouble I suppose when you have cars that are from a crossover period.
Offline DanChave
Re: MK3 1.8T
« Reply #26 on: 19 December 2011, 16:30 »
Definitely true man!
Offline BISSONE
Re: MK3 1.8T
« Reply #27 on: 19 December 2011, 19:41 »
If you buy a 16v though that would be wide track, am i wrong in thinking that if u changed the hubs from 5 stud to 4 stud would the drive shaft splines match 4 stud hubs? Before i get my head bitten off i dont know so chucking that one out there?
Offline Ferdinor
Re: MK3 1.8T
« Reply #28 on: 19 December 2011, 22:52 »
Well i much prefer 4 stud rims to 5 stud and im not really into adapters, if im going through a complete car build/converstion i may aswell change it to how i want it  :laugh:
As for this? is this true does anyone know? as this may cause me some problems? thanks for putting the point out there, you might have saved me some ball ache?  :huh:
cheers
Re: MK3 1.8T
« Reply #29 on: 19 December 2011, 23:27 »
If your using a 16v (5 stud) as a base car stick with 5 stud, adaptors need to be custom made and are mega bucks, to convert back to 4 stud is not really easy, so many different ways but you may as well get wheels that fit and save the money.
« Last Edit: 20 December 2011, 00:01 by Wayne »
