Author Topic: Dodgey noise from mk4 front wheel/suspension...  (Read 2299 times)
Offline Gabriel2202
« on: 18 December 2011, 17:17 »
I recently took a long drive down to luton and when I got there i was hitting numerous roundabouts and noticing that when i turn left my car (mk4 1.8t) makes a noise, similar to that of when a cv joint goes but a bit more grinding and vibrating, from the front drivers side... I had the driveshaft replaced month ago and only just got my car back from having the brake system done  :sad: It does it at every speed, only when turning left and it doesnt seem to matter if I'm under acceleration or not...
I have been reading that it could be a wheel bearing or a knackered damper but dont have the money to throw loads of parts at it so was wandering if anyone has had similar issues and any ideas on what it could be?
Any help is really appreciated  :smiley:
Thanks
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline richw911
Re: Dodgey noise from mk4 front wheel/suspension...
« Reply #1 on: 18 December 2011, 17:26 »
Top mount? Wishbone bush? ARB bush?  :undecided:
Offline Gabriel2202
« Reply #2 on: 18 December 2011, 17:37 »
Ah right, Is there anyway to visually check which of these its likely to be?
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline richw911
« Reply #3 on: 18 December 2011, 17:50 »
With the Wishbone and ARB yes would be best to get it on a ramp to look and check for movement  :smiley:
Offline Gabriel2202
« Reply #4 on: 18 December 2011, 23:29 »
Thanks for the advice, I'll jack it up tomorrow and have a feel  :smiley:
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline dilbert
« Reply #5 on: 24 December 2011, 17:06 »
Jack it up. Feal for movement in front wheel. Left to right and up n down
Spin the wheel up. Listen for any noises. Rumbling ? Grinding ?
Take wheel off check cv joint. Ball joints and coil spring is complete and not snapped ?  Also turn left to right see if you can hear the noise clearer when up close
mk4 golf 1.8 gti 20v
