Author Topic: Newbie needs some help!  (Read 1567 times)
Offline magnus
« on: 11 May 2005, 19:00 »
 Hey everyone!
Hello VW dudes and dudettes! My name is Magnus and i am in Greece.
I am a new VW fan as i just got a Mk1 Cabrio.
The car is a 1.5 carb model and i need some advice....actually i need alot of it.
The engine is in a bad state as it needs new rings and most likely a valve. I am planning on a fairly big restoration including a respray. I ve already got some part for it but need to see what i ll do with the engine. So far i ve managed to collect the following parts: Gearbox from a GTI, oil cooler, new bumpers, driveshafts and wishbones from a GTI and a few other bits.
 My problem is this, as the car is a carb model i want to avoid converting to fuel injection, However i have been offered a 1.8 8V from a Mk2 for nothing. Is there a way to install that engine on the carb? I know the injectors are on the head and therefore cant be used. So i was wondering if i can use the head of the 1.5 on the 1.8 block. If this is possible what else will i need?
Would it be more sensible to just send of the original engine for new rings and do the head? Maybe if i sent of the 1.5 head to be modified for the 1.8 block? Or maybe a cheap and simple way to use the 1.8 engine with the carb from the 1.5?
 Also are there any things i can do to increase power with out spending a fortune? I dont want a street racer or something, just a bit more poke.
Please help me out guys as i need to get the car on the road asap!
Best advise wins a few pinds if you ever are around this side of the world! :smiley:
Offline monkeyalan
Re: Newbie needs some help!
« Reply #1 on: 11 May 2005, 19:21 »
I should think the easiest and cheapest thing to do would be fit the 1.8 lump and fit a new carb, a twin choke webber of some sort. obviously , it's not straight forward but i'm sure it's quite possible.
i'm sure someone with greater experience will tell you more soon.
oh yeah, hello :smiley:
Offline magnus
« Reply #2 on: 14 May 2005, 12:52 »
 Thanks, and although that is what i thought i have no idea how to plug the injector holes on the head!
Anyone know if the 1.5 head will go on?
Offline black_cabbie
  • If they don't have a golf in heaven I am not going
« Reply #3 on: 28 May 2005, 01:47 »
You are from Greece? Kai ti akribos kaneis edopera? hehehe
email me at maxkoutsis @ hotmail.com and I will give you all the info you will ever need!
1.8L 8V Digifart, AMS chip, Kent 270 camshaft, TT Adjustable Cam Gear, Supersprint Header with supersprint catless system, BMW AFM, Adjustable FPR. G60 Green 23lb injectors coming soon.... =)
Offline richandhazel
« Reply #4 on: 31 May 2005, 01:22 »
I think your best option is to use the 1.8 head, just leave the injectors in, to plug the holes.
I also think the 1.5 head will fit the 1.8 block, however, I stand to be corrected.
