Author Topic: front disk rusty outer and inner ring,wheel balancing weights.  (Read 1272 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
As title drivers side front disk has a ring on outer and inner dia on the contact face that is going rusty all other disks are fine and shiny after being driven.also washed me car earlier and a small balancing weight fell off wheel will this cause problems feels ok to drive,gettin two new front tyres next month will it be ok to drive until then obviously will be rebalanced with new boots.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline mcgee9t2
Re: front disk rusty outer and inner ring,wheel balancing weights.
« Reply #1 on: 18 December 2011, 16:42 »
Wheel weight will make your steering wheen wobble at certain speeds might not notice it till you get on the motorway
Offline symsymma
« Reply #2 on: 18 December 2011, 16:53 »
Ok thanks goin out in a bit gotta go down dual carriage way wil c wot its like then.think ill just leave it til i get me tyres then. :smiley:
Offline Steve_PD
« Reply #3 on: 18 December 2011, 17:18 »
You'll get a little wobble around 60-70 nothing Id worry about.
The rust is it on the inner and outer edges of the disc? If it is thats normal
Offline symsymma
« Reply #4 on: 18 December 2011, 17:28 »
Ther were four weights in a row and only ones come off about a 15mm square.rust is on the face of disk on outer edge and near hub should be shiney its the only one like it :undecided:
Offline mcgee9t2
« Reply #5 on: 18 December 2011, 17:31 »
disks are normal dude, mine are like that, its just were the pad hasent been in contact with the edge of the disk
