Golf mk4
Golf mk4 TDI
Wazzzer
dropped drivers door on my 2003 tdi
Topic: dropped drivers door on my 2003 tdi (Read 2501 times)
Tucky
GTI forum regular
why do it today when you can put it off untill tmz
18 December 2011, 13:12 »
Hi all on my golf mk4 tdi the drivers door has dropped slightly compered to the others
got in it this morning wet seat and soaking wet carpet also water build up at the bottom of the door sill. Is this easey to fix re re hanging the door and replaceing the rubber door seal thanks
Steve_PD
Serious forum addict
Cruising around in a Land Cruiser
Re: dropped drivers door on my 2003 tdi
18 December 2011, 13:28 »
3 options
1: Open door slightly and use a jack to lift the door back up. Use a rag to protect the paint
2: If you got the tools you can put a washer behind the hinge to raise the door
3: Buy new hinge
Tucky
GTI forum regular
19 December 2011, 18:51 »
got it checked at work turned out it was the door seal so not that hard a job luckily
Golf mk4
Golf mk4 TDI
Wazzzer
