Author Topic: alternator/battery hassle  (Read 1148 times)
Offline insane21
« on: 18 December 2011, 06:58 »
merry christmas all, fitted new alternator yesterday and my car still cuts out, the two batteries i have are pretty flat it must be said, i thought the alternator would charge it/them back up but no, suspect i might have a short/break in the system? anyone else had similar experiences or tips?
Offline richw911
Offline stevelfc
Re: alternator/battery hassle
« Reply #2 on: 18 December 2011, 10:29 »
check the wireing to alternater make sure contections are clean and no brakes in the wireing also check earth straps are clean  :wink:
Offline insane21
« Reply #3 on: 18 December 2011, 11:12 »
Thanks rich top man, ill lok at this now  :laugh:
yes thats it, the alternator fuse on the battery was cooked, oh well now i have a spare battery and alternator!
« Last Edit: 21 December 2011, 06:26 by insane21 »
Offline richw911
« Reply #4 on: 21 December 2011, 12:17 »
Glad you got it fixed  :cool: :cool: :cool:
Offline Mike671
« Reply #5 on: 21 December 2011, 19:38 »
Probably cooked as your alternator was overcharging as the regulator had gone or because the battery was dead as a dodo
« Last Edit: 21 December 2011, 19:39 by Mike671 »
Esplanade V.W Audi Mercedes And Smart Tech
Offline insane21
« Reply #6 on: 22 December 2011, 08:33 »
what happened was that the last owner decided not to replace the fuse box on the battery and put a temp chunky fuse on the alternator connection instead, all the connections were loose! next problem i have is cutting out when the revs drop, i think maf sensor as its more electronic/twitchy idle + when i changed my air filter for a k+n i did not secure it in place, and its had a beating against the chassis!
« Last Edit: 22 December 2011, 08:41 by insane21 »
