Author Topic: Silly Question ! i forgot to check before removing : HELP :  (Read 1503 times)
Offline irish
Hey everyone :)
Really quite a silly question but i've been having alot of problems with my fuel gauge i removed it once to to do a job but forgot which way it is ment to go back in. What way should the arrow on the top of the pump in the tank be facing ??????? any pictures lol
also having a problem removing the o/s front lower arm bush bolt... it just seems to keep turning ?
Many Thanks Glyn :)
Offline irish
Re: Silly Question ! i forgot to check before removing : HELP :
« Reply #1 on: 18 December 2011, 11:52 »
most helpfull site ! :angry:
Offline Steve_PD
« Reply #2 on: 18 December 2011, 12:34 »
Not to sure what your asking in regards the first question. What way the fuel gauge in the dash goes in? :undecided:
Does the bolt have a nut above it? If it doesnt its a captive nut which has broken free. You'll have to cut the bolt off and either weld a nut in place or get a garage to insert a new captive nut.
Offline vwblackmk4gti
« Reply #3 on: 18 December 2011, 12:34 »
in terms on the fuel gauge are you talking about the guage on the clocks or the fuel pump in the tank. next thing which lower arm bolt are you talking about because theres 2.
the one that is horizontal?
or
the one that is paralell ?
Offline mcgee9t2
« Reply #4 on: 18 December 2011, 12:52 »
nope just you posted this at 11:30 when most people are either out trollied or watching tv or generally having a life and then expected people to post before 11 on a weekend when most people have a lie in on the weekend, give people a chance to answer and they might be more helpfull cause 90% of the time that youve gave people will have been asleep :)
sorry i cant help you with your question hope you get it sorted
« Reply #5 on: 18 December 2011, 13:02 »
more info is needed to give you a more accurate anwser,
Offline irish
« Reply #6 on: 18 December 2011, 15:13 »
i said the FRONT Offside bush the very FRONT one i think the captive nut has snaped off but cannot access it !
if someone could look at the TOP of the fuel pump in the TANK and see what way the arrow is pointing ... thats all i need to know guys :)
Offline Dave_IOW
« Reply #7 on: 18 December 2011, 16:39 »
One points in, one points out.. :huh:
Because, one is an inlet and one is an outlet?   :grin:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline dom
  • Back in a Mk4
« Reply #8 on: 18 December 2011, 18:33 »
Most arrogant 'irish' :rolleyes:
