Author Topic: Overall ride height ?  (Read 1590 times)
Offline Shivas Regal
« on: 17 December 2011, 23:10 »
Sourced a set of Boge turbos with 50mm lowering springs for an 8v Gti.
Plans on putting these on a 16v
Will it be too low due to difference in weight of the two engines?
Am a mature driver and dont want anything crashy. Am thinking will prob have to bin the springs?
Re: Overall ride height ?
« Reply #1 on: 17 December 2011, 23:33 »
They will be fine, not much difference in weight between the 2 engines.
Offline SoundillusioN
« Reply #2 on: 18 December 2011, 00:02 »
Be alright, Who are the springs made by?  Generally Boge shocks are very good, I rate them.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 18 December 2011, 00:02 »
minus 50mm on a 8V should equate to minus 40mm on a valver...
So shouldn't be too low - as to crashy it will depend on the springs that you fitting...
For More Info Click To See;
Offline Sam
  • Sam I am
« Reply #4 on: 20 December 2011, 15:52 »
As stated, no real difference in block weight so will be fiiiine
