Author Topic: Golf iv 1.8t agu motor ,ignition amp module/amplifier  (Read 1866 times)
Offline donno
« on: 16 December 2011, 18:33 »
Hi Al
I would like to know if you should put thermal compound on the ignition amp when fitting the part back on the airbox.Many thanks for any advice.
jamie16v
Re: Golf iv 1.8t agu motor ,ignition amp module/amplifier
« Reply #1 on: 16 December 2011, 18:37 »
yes!
Offline blade4real2004
  • golf gti with a touch of .:R
« Reply #2 on: 16 December 2011, 19:01 »
Yes that what I used helps with the transfer of heat
k04s | jabba cai | stage 2 (Rtech) | forge 007p | forge boost hose set |forge tip | THS fmic | gen r line kit | bbs ch | TT short shift | R32 vents | full stainless | decat | auto windows | mk5'd boot
need a scan or mod with vagcom & vagtacho PM ME (south wales area)
my build thread - http://uk-mkivs.net/forums/t/236415.aspx?PageIndex=1
Offline CarlGallagher
« Reply #3 on: 16 December 2011, 20:12 »
DEFO!!!! lad i purchased my agu off did not put the heat conductive paste on and sure enough on a hot summers day it went.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 16 December 2011, 20:58 »
yep and buy some good stuff too :wink:
