Author Topic: temp light  (Read 1206 times)
Offline boyob32
  • 1.8T
temp light
« on: 16 December 2011, 17:56 »
I had the dreaded temp light cone on today, then disappear.
Coolant level fine, pump and belt changed 3000 miles ago, heating working and engine temp nicely on 90. Any ideas??
Offline pickles
  • Next!!!
Re: temp light
« Reply #1 on: 16 December 2011, 23:56 »
dodgy switch/sender, wiring fault perhaps
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline richw911
Re: temp light
« Reply #2 on: 17 December 2011, 10:12 »
Corroded sensor in the coolant botttle  :wink:
Offline boyob32
  • 1.8T
Re: temp light
« Reply #3 on: 17 December 2011, 22:15 »
Ahhh the one thing I didnt think, will check that out! Cheers  :rolleyes:
Offline richw911
Re: temp light
« Reply #4 on: 17 December 2011, 22:18 »
A bottle is about £12 brand new from vw  :wink:
Offline boyob32
  • 1.8T
Re: temp light
« Reply #5 on: 17 December 2011, 22:21 »
Cool. Another question, today I also had a drop in my revs while idle which then stabilised, early to tell I know, but could this be the temp sender?
Offline richw911
Re: temp light
« Reply #6 on: 17 December 2011, 22:23 »
Maybe, could need a throttle body clean  :smiley:
Offline boyob32
  • 1.8T
Re: temp light
« Reply #7 on: 17 December 2011, 22:29 »
Thats the more preferable outcome! Think I might give the car some new / cleaner parts this weekend! Well see how it works out!
Offline richw911
Re: temp light
« Reply #8 on: 17 December 2011, 22:34 »
Scan it for fault codes first http://www.golfgtiforum.co.uk/index.php?topic=87783.0
