Author Topic: G60 16V IS THIS POSSIBLE  (Read 5800 times)
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« on: 11 May 2005, 10:39 »
HI THERE I WAS IN NEED AF A HEAD GASKET FOR MY KR 16V MK2 GOLF AND FANCIED A SUPERCHARGER SO GOT THE G60 ENGINE BOX ETC IS IT POSSIBLE TO MAKE A 16V SUPERCHARGED ENGINE WITH THE TWO LUMPS? WHAT ELSE WOULD I NEED
Offline Mr Blue
Re: G60 16V IS THIS POSSIBLE
« Reply #1 on: 11 May 2005, 11:32 »
there was a website that did this conversion and showed the parts/part numbers. duno where its gone now.
Its possible yes :cool:
Offline ...joe
« Reply #2 on: 11 May 2005, 11:34 »
yeah its possible, heres my mates corrado to prove it!!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline jettaTx
« Reply #3 on: 11 May 2005, 13:31 »
CAN ANYONE GIVE ME ANY IDEAS OF HOW TO DO IT ? THANKS
Offline Gambit
« Reply #4 on: 11 May 2005, 13:54 »
Offline jettaTx
« Reply #5 on: 13 May 2005, 10:42 »
RIGHT IM GONNA HAVE A CRACK AT GETTING THIS SORTED, IVE DECIDED TO PUT THE 8V G60 UNIT IN FIRST THEN BUILD UP MY 16V ENGINE TO THE CORRECT SPEC NEEDED PLUS IVE GOT SOME SAVING TO DO!! IM GETTING THE 8V UNIT IN FOR 1300 ALL IN IS THIS A GOOD PRICE N E ONE?? PLUS IF ANYONE HAS A SCIROCCO 16V INLET MANIFOLD I WOULD BE VERY INTERESTED!
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 13 May 2005, 10:53 »
i've got a 'rocco 16v inlet sitting in my living room, right next to my jmr ported 16v head, neither of which are for sale :tongue: :grin:
Pistons will probably be your biggest material expense (after the bahn brenner kit, if thats the route you're choosing) , Audi RS2 pistons will do the job.. im looking at getting some custom made for mine so that i can keep the oil cooling jets in the chambers though.
If i were you i'd leave your car running the 16v and build up the 16vg60 in a garage then just drop it in when done, easier to make things fit that way when (not if) you change your mind on the parts you're using :grin:
Offline BobbyT
« Reply #7 on: 13 May 2005, 11:17 »
hi, where are you getting the g60 engine fitted? does the price include the engine? if so that is within my budget! :grin:
could you let me know? cheers rob
Offline jettaTx
« Reply #8 on: 13 May 2005, 11:29 »
I got the engine and box from Ebay! and all the other bits needed aswell. I am getting the work done through a Garage i supply parts to. I am getting a special rate on the labour. They haven't done one before so once its done and they r happy i will let ppl know where i have got the work done. Andy
VeeDubGTI16v
« Reply #9 on: 13 May 2005, 17:40 »
i would use a different manifold than the scirocco one if you can because they sound like they are stoopidly rare and they ae right above the engine so the air gets a bit hot. get one that comes out the front like on the 1.8t's
