Author Topic: Strange Message on Dash Display on Cold Mornings  (Read 2810 times)
Offline samhain1
« on: 15 December 2011, 23:46 »
My Mk5 Golf GTI seems to have developed an ECU fault or some other sensor fault. Can anyone help.
Since the start of the cold weather I get the coolant light coming on in the car and the message STOP on the display. However, all is wel lwith my coolant which was changed this year following my timing belt and water pump change. When I switch the engine off and on a couple of times the warning disappears and I can drive the car fine for hours.
Any clues?
Thanks
Stu
Offline richw911
Re: Strange Message on Dash Display on Cold Mornings
« Reply #1 on: 16 December 2011, 10:05 »
The coolant bottle has metal prongs - when there is not enough water in there it cuts the circuit and throws on the dash light ,What normally happens is the metal parts get corroded and it thinks the water is low.
You need to clean the prongs in the bottle or replace it like i did only £12  :smiley:
Offline Snooze
« Reply #2 on: 16 December 2011, 19:13 »
Yep I had the exact same problem.  Coolant expansion bottle needs replacing.
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline samhain1
« Reply #3 on: 14 January 2012, 21:10 »
Cheers guys that's helpful.
Might seem like an obvious question but to I need to empty the system in order to chage the expansion tank. Obviously there is nice pink antifreeze fluid in the tank
Offline Gene Hunt.
« Reply #4 on: 15 January 2012, 07:15 »
..............don't think so.Just remove the lower pipe(place container under it  :grin:).Once empty just remove the tank & replace with new one & re-connect pipe & refill with coolant.
Candy White ED35.
Offline samhain1
« Reply #5 on: 15 January 2012, 09:15 »
Brill
Offline samhain1
« Reply #6 on: 16 January 2012, 20:13 »
Have just ordered a new part £17 including vat from the stealers will just need to swap it over for the broken one
Offline Gene Hunt.
« Reply #7 on: 17 January 2012, 19:12 »
............good price. :smiley:
Candy White ED35.
