Author Topic: 1986 engine swap  (Read 1924 times)
Offline iamcanadian
1986 engine swap
« on: 23 September 2003, 09:24 »
hi i have an 86 MKII 8v right now and i want to put a vr6 engine in it's place. what vr6 engine would be best/easiest? is this a difficult swap and what else would need to be changed? thanks everyone for your help.
Offline Dizzie
  • Make friends with your fast
Re:1986 engine swap
« Reply #1 on: 24 September 2003, 23:35 »
A MK3 Golf would be the best donor. What needs changing? just about everything! (loom, cooling, brakes, suspension, la, la, la). You get the idea.
I wouldn't advise cutting corners and leaving the brakes and suspension with the power and weight hike you may find it a bit lairy when it comes to hauling on the ancors in a hurry :D
Someone else will have better answers than me though :)
Mk4 Golf 150PD
golfvr6
Re:1986 engine swap
« Reply #2 on: 25 September 2003, 13:08 »
Vr6 in a mk2 is quite a common conversion now, will cost you sh!t loads!
