Author Topic: Rubbing strange sound  (Read 1390 times)
Offline AlexMozza
« on: 15 December 2011, 00:48 »
My MK3 has started developing a strange squealing/rubbing sounds from the breaks, I've had them off and they do nOt look warped or scored. It has only just started happening. Could it be a wheels bearing, the sound is morenoticible when breaking and at low speed.
Either that or I was thinking a sticking calliper.
Can anyone shEd a light on this :)
Thanks
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
Offline SoundillusioN
Re: Rubbing strange sound
« Reply #1 on: 16 December 2011, 15:34 »
Thanks
How new are the pads/discs?  had them changed recently?  was copper grease applied when they were done?
Rare but possible stone or some grit wedged between a pad and a disc?
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #2 on: 16 December 2011, 15:39 »
A sticking caliper will usually cause that particular wheel to get hot so check that next time. You sure, cause ypu notice it at low speeds its just not surface rust on the discs caused by the salt on the road. Usually heard when first setting off but usually clears itself up. My car is like this every morning recently.
« Reply #3 on: 16 December 2011, 20:59 »
Give a run (trying not to use the brakes much) and see when you get back if any wheels are hot if so you have a caliper sticking.
