Author Topic: cut out  (Read 1149 times)
Offline raggywestwood
cut out
« on: 13 December 2011, 18:59 »
hiya all,
just a quick one my mk2 gti 1991 8v is struggling on idle and sometimes when i approach say a rundabout or traffic lights it sometimes cuts out but then i re start it idles ok then may struggle, i am going t change the maf unit, the blue temp sender, the idle valve and i think that should cure it, was just wondering if anyone else agreed or had any other ideas?
any ideas most welcome
cheers guys.
Offline sparkplug
Re: cut out
« Reply #1 on: 14 December 2011, 15:14 »
 check your air pipes for leaks too
1986 GTI atlas grey
Offline Sam
  • Sam I am
Re: cut out
« Reply #2 on: 14 December 2011, 16:00 »
Sounds like the ISV to me buddy, I had the exact same problem  :smiley:
Offline Mitching
Re: cut out
« Reply #3 on: 14 December 2011, 16:11 »
Check and clean ISV and throttle body and air intake!   :smiley:
Offline dadrathers
Re: cut out
« Reply #4 on: 15 December 2011, 21:32 »
Check the idle switch too. Do a search on here for how to set it. To check that it is working is dead easy, don't even need the car running.
I suggest you only change one thing at a time otherwise you won't know what fixed it???
