Author Topic: Gear box rebuild  (Read 1527 times)
Offline siddleg
Gear box rebuild
« on: 13 December 2011, 18:53 »
Evening all
i had the call today from the garage informing me that my slipping clutch is due to an oil leak and the only 1005 cure would be a rebuild with all new seals etc  :embarassed: he is replacing the dodgy seal but reckons it will only last so long if there is play in the shaft. gutted  :cry:
how much is it likely to cost for a rebuild with seals, bearing and second gear synchro ?
Offline tech1889
  • Mk2 GTI FTW !!
Re: Gear box rebuild
« Reply #1 on: 13 December 2011, 18:55 »
£450ish
Offline Sam
  • Sam I am
« Reply #2 on: 13 December 2011, 21:14 »
You will be better off buying a second-hand box of egay an putting it on yourself, do the clutch whilst your at it using the money you have saved  :smiley:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #3 on: 13 December 2011, 21:20 »
Yes.This.
Offline rob.043
« Reply #4 on: 14 December 2011, 09:06 »
yeah, there was someone listing reconditioned gearboxes for £350-450 on ebay, with everything done, or you can find a non-reconditioned working one for as little as £50
Offline siddleg
« Reply #5 on: 14 December 2011, 12:52 »
Second hand one sounds ok but there is no gaurantee that it will be any better
think ill check ebay for the recon items
im in east yorkshire who would you you recommend for the rebuild if all else fails
cheers
Offline mk2bal
« Reply #6 on: 14 December 2011, 18:16 »
If an 8v, I'd just chuck another 2nd hand £50 8v 020 in.. If kr/abf, do it properly and do 02a cable change box, along with hydro clutch. All that along with a brand new vr6 clutch is still way less than £4-500! Cars future proofed for more power, and the mk3 02a boxes are stronger and lower mileage available. All 16v boxes crunch already, or are on their way out unless been rebuilt. When mine went there was no way I was going to spend that sort of money on a rebuild, when if I 20vt one day I'll need all the 02a bits for a proper job anyway.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #7 on: 14 December 2011, 18:18 »
my 8v one crunched 1st to 2nd was so annoying lol
