Author Topic: onboard trip computer mk golf gti  (Read 5074 times)
Offline paddy2011
« on: 13 December 2011, 15:21 »
Hi guys I'm in need of some help, I've got a v reg mk4 golf gti and the trip computer lights up but doesn't display anything, if anyone could shed some light on this problem it would be a great help to me
Offline BarryMKIV
Re: onboard trip computer mk golf gti
« Reply #1 on: 13 December 2011, 16:10 »
Are you just seeing a red screen? This happened on my old golf, I was told the cluster would have to be changed. I drove around with it like that for months, until one day when I was cleaning the car I left the stereo on, completely drained the battery, and had to jump the car. Jumped the car. Screen came back. Never had a problem after that. So might be worth trying to disconnect your battery for a while and see if it comes back when reconnected?
If that doesnt work. Clean your car. Leave the stereo on whilst doing so. Drain the battery. Jump start it. And see if that works  :smiley:
25th Anniversary GTI 1.8T No. 0441
Offline dvvid1993
« Reply #2 on: 13 December 2011, 19:10 »
as said above try disconnecting the battery failing that look for the instrument cluster on ebay (very cheap) will need vw software to reprogram the immo tho.
Offline paddy2011
« Reply #3 on: 14 December 2011, 12:37 »
Thanks for the help, yes it was just a blank screen, I've disconnect the battery and the little screen is still blank,  :sad:
« Reply #4 on: 14 December 2011, 13:58 »
Sounds like your cluster is dead then. :sad:
Offline BarryMKIV
« Reply #5 on: 15 December 2011, 16:07 »
Probably best off replacing them so. Cheap enough these days, and a good excuse to upgrade if you only have the standard clocks at the moment.
http://www.ebay.co.uk/itm/VW-MK4-Golf-Anniversary-Petrol-Half-FIS-Clocks-VDO-1J5-920-926-Rare-/320813809470?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab1fe3f3e#ht_500wt_1198
