Author Topic: Alloy wheel bolts.  (Read 1073 times)
Offline LowlifeDubber
Alloy wheel bolts.
« on: 13 December 2011, 13:27 »
Now then,im just about to get some non oe wheels for her mk4 1.6 16v.
Just wondering if i need to buy some new wheel bolts as they could be a different taper?
She currently has standard vag 15" factory alloys on.
Can i use these or do i need some new ones or is it wheel dependant?
Cheers lads.
Gaz
Offline bullzeye
Re: Alloy wheel bolts.
« Reply #1 on: 13 December 2011, 13:32 »
sure someone on here will know for sure but when i had my 1.4 i bought some rs8 alloys and my wheel bolts were too short and the wheels rubbed on calipers so needed spacers  and had to order some longer bolts one from a parts shop, the wheels came of a gti which they fit fine without the spacers   :sad: so i dont think there all the same
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
« Reply #2 on: 13 December 2011, 13:51 »
All / most aftermarket alloys are different taper bolts to standard so yes you will need different bolts.
Offline Dave_IOW
« Reply #3 on: 13 December 2011, 19:26 »
Aren't OE tapered and aftermarket radius?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Steve_PD
« Reply #4 on: 13 December 2011, 19:38 »
No OE is radius and aftermarket is Tapered. Jap stuff is usually tuner bolts
Offline Dave_IOW
« Reply #5 on: 13 December 2011, 19:42 »
Thats what i meant  :grin:
 :rolleyes: :embarassed:
« Reply #6 on: 13 December 2011, 20:20 »
Cheers lads,so i need a tapered bolt set then :)
Im guessing i will have to get a new locking wheel nut set too then :angry:
Offline Steve_PD
« Reply #7 on: 13 December 2011, 22:18 »
Id fire off an email to the seller before you buy to find out what bolts are required. Mine are aftermarket but use radius bolts
« Reply #8 on: 13 December 2011, 22:24 »
Well he's moved in round the corner from me and he has lost the key to his lockers so I've got to buzz them off for him so when I do I think I will just steal his bolts and buy a new mcguard set of lockers.
I will make sure they are tapered bolts 1st though lol
