Author Topic: braking revs..is this normal  (Read 1210 times)
Offline 1.6mk4GOLF16v
« on: 13 December 2011, 10:04 »
Just noticed when i pump the brake pedal the revs go up when at stand still, this normal? or is there something need checking?
:undecided:
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline AD1.8T
Re: braking revs..is this normal
« Reply #1 on: 13 December 2011, 10:56 »
When its idleing ?
« Reply #2 on: 13 December 2011, 11:08 »
do you mean how far will the revs go if i keep pumping?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline AD1.8T
« Reply #3 on: 13 December 2011, 11:28 »
Na does it do it when the engines running but your not moving when the cars just ticking over ? Youl notice if you turn the steering wheel lock to lock the revs will dip aswell .... I presume its just were the cars drawing power to something else i would try it with the brakes but my cars kind of in pieces. All the cars ive driven have done the same with the steering though
« Reply #4 on: 13 December 2011, 12:07 »
yep dips when i turn the steering wheel full side to side
bounces a bit when idle but nothing major
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #5 on: 15 December 2011, 12:53 »
any ideas?
MAP sensor perhaps?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline mk3.owner
« Reply #6 on: 16 December 2011, 03:58 »
All my car's have done this.. I didnt see it as a problem as it's Power Steering and ABS. They need power from somewhere.
