Author Topic: no cold air in car after doing matrix  (Read 2204 times)
Offline Oet
« on: 12 December 2011, 19:12 »
i did my heater matrix recently, and rebuilt the foam in the airbox, i now have heat but when i adjust the settings to cold on the dash i still get heat, plus there doesnt seem to be loads of air going to the dash vents, despite the fact i know i connected everything up (ie all the ducting) so have i put the flaps in the wrong way in the airbox, or connected the flaps to the cables incorrectly?
any ideas?
thanks
Offline Thom89
  • Looking for an "Icebreaker"
Re: no cold air in car after doing matrix
« Reply #1 on: 12 December 2011, 19:30 »
You need to recheck the cables are connected on the back of the dash, likely the one has become detached!
Thom
« Last Edit: 12 December 2011, 19:33 by thom89 »
Offline Oet
« Reply #2 on: 12 December 2011, 19:47 »
how do you mean thom, the cable into the selector mechanism (the bit at the top) or the cable as it clips into the airbox housing at the bottom with those annoying clips?
Offline Andy!
  • VR6
« Reply #3 on: 12 December 2011, 20:14 »
I'd check them both pal.
Offline garethmarshall
« Reply #4 on: 12 December 2011, 20:18 »
i done heater matrix the other day and had that exact problem thom. not much else can go wrong tbh mate
gareth marshall
Mk2 Golf 2.0GTi
MY BUILD:
http://www.golfgtiforum.co.uk/index.php?topic=219164.40
Offline Thom89
« Reply #5 on: 13 December 2011, 00:33 »
Both slider controls should have a little resistance when operated, If the   COLD..===...............................HOT  moves too easily, then the cable, or the outer has become detached at the back iirc you can pop the slider control unit from the front of the dash, hopefully, its that end that needs fixing, otherwise you're going to have  to get the kit out again :rolleyes:
Thom
Offline Oet
« Reply #6 on: 13 December 2011, 17:02 »
they have resistance, thats the problem, its def moving stuff, just getting cold when i move the lever, so i recon the airbox cant be directing the flaps properly. Will check the dash end first, am dreading having to do the other end, that was a right pain
Offline Thom89
« Reply #7 on: 13 December 2011, 17:39 »
Does the slider have too much resistance? It could be hooked up on something...
Thom
Offline Sam
  • Sam I am
« Reply #8 on: 13 December 2011, 17:51 »
Thom
Yer, does your car rev when you turn it up  :evil: :grin:
Offline Thom89
« Reply #9 on: 14 December 2011, 01:00 »
Thom
Very good Sam :grin:
Thom
