Author Topic: vw golf gt-tdi 150 gearbox problens???????????  (Read 3705 times)
Offline andygttdi150
« on: 12 December 2011, 18:01 »
 :smiley:
hello
problem with my golf mk4 gearbox.. code EEF.. when its cold its hard to get it into gear?. once its warm its fine.
i`ve changed the gear oil. not sure if it was correct oil. cheap stuff from halfords.....
does anyone the correct oil for my car? and is there any knowing issues with the 6 speed EFF gearbox
thanx andy
merry christmas
 :laugh: :tongue: :shocked: :undecided: :evil:
Re: vw golf gt-tdi 150 gearbox problens???????????
« Reply #1 on: 16 December 2011, 21:07 »
Better to drain it and fill it with the correct / genuine oil, to be easier when warm suggests oil that is too thick.
Offline xxChrisxx
« Reply #2 on: 16 December 2011, 21:46 »
:smiley:
hello
Has it started doing it since you changed the oil? Or did it prompt the change?
This can be just a symptom of age, as the synchros start to wear you'll require more shift effort.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #3 on: 19 December 2011, 01:09 »
What condition was the old oil when you drained it? I would pickup the correct VW spec oil from VW parts counter/TPS and change it, worth checking shifter adjustment too?
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 19 December 2011, 06:07 »
Any idea whether the clutch has ever been changed?
« Reply #5 on: 24 December 2011, 22:08 »
hi everyone.
  thanx for your suggestions. change the gear oil for the vw oil. its sorted
can`t believe something so small could make that big of a differance.
 porblem sorted.
merry christmas and all the best for 2012[/font]
