Author Topic: Bad Idle ?  (Read 2659 times)
Offline richw911
Re: Bad Idle ?
« Reply #10 on: 13 December 2011, 18:00 »
Hold throttle wide open/ engine off and intercooler pipe off and get a cloth with carb cleaner on it and get cleaning .No need to remove it.  :wink: My hand fits inside that hole.  :evil: I just did mine again ,runs sweat.
Much better to remove it and clean it properly imo  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Bad Idle ?
« Reply #11 on: 13 December 2011, 18:18 »
mine never needs cleaning  :smug:
Offline richw911
Re: Bad Idle ?
« Reply #12 on: 13 December 2011, 18:22 »
Catch can  :cool:
Only done mine twice never been too black or had poor running because of it  :smiley:
Offline pickles
  • Next!!!
Re: Bad Idle ?
« Reply #13 on: 13 December 2011, 18:28 »
ended up taking the TB off for all it was and gave it a good scrub , its shiny now
:), seems to idle a lot better although slightly higher RPM, its just over 1000 but is no longer spiking like it used to, will the revs flatten bk down to around 900 (which im sure is an average idle, correct me if im wrong ) or is this normal.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline richw911
Re: Bad Idle ?
« Reply #14 on: 13 December 2011, 18:29 »
Yep just drive it a few miles that should do it  :wink:
Offline pickles
  • Next!!!
Re: Bad Idle ?
« Reply #15 on: 13 December 2011, 18:37 »
cheers bud, :), oh n whats with the catch can, does that stop the TB from getting all sh!tey
Mapped
Nearly S3 time  :)
Offline richw911
Re: Bad Idle ?
« Reply #16 on: 13 December 2011, 18:45 »
http://uk-mkivs.net/forums/t/269734.aspx  :smiley:
