Author Topic: What is this thing and does it matter if i broke it ?  (Read 1252 times)
Offline AD1.8T
The hose that comes off of the circle thing ...... I kinda snapped the connector pipe off of the inlet manifold what does it do and can it be sorted without buying a new manifold ????
Offline rio_gti
Re: What is this thing and does it matter if i broke it ?
« Reply #1 on: 12 December 2011, 10:15 »
Vacuum to fpr is needed buy a tee and cut it into one of the other vacuum pipes off the manifold and then where u snapped the nipple off drill and tap it out then get some jb weld and use the jb as a sealent and thread the bolt into the manifold
Offline AD1.8T
« Reply #2 on: 12 December 2011, 10:32 »
So it would be easier to get a new manifold then really ???
jamie16v
« Reply #3 on: 12 December 2011, 12:02 »
by looking at the pic there seems to be two things disconnected.. could you give more of a descritption of the part you are refering to?..
Offline pickles
  • Next!!!
« Reply #4 on: 12 December 2011, 12:23 »
That loose pipe from your FPR (circle thingy lol) should go str8 into the bottom side of your intake manifold. AGU engine anyway.
dunno what that black thing is thats diconnected tho
just teed a boost gauge into mine yesterday hence me knowin lol
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
jamie16v
« Reply #5 on: 12 December 2011, 12:42 »
get some 4mm silicone hose as your original stuff will be perished.
Offline pickles
  • Next!!!
« Reply #6 on: 12 December 2011, 12:45 »
sorry to hijack the thread but iv been looking at upgrading my hoses as well, how much 4mmtubing would be required for a AGU engine.
Mapped
Nearly S3 time  :)
jamie16v
« Reply #7 on: 12 December 2011, 12:47 »
it depends what you got, if you got a boost guage then get about 3m if not then about 1m should suffice..
Offline pickles
  • Next!!!
« Reply #8 on: 12 December 2011, 12:49 »
nice 1 thanks, looks prettier as well ;) lol
Mapped
Nearly S3 time  :)
Offline AD1.8T
« Reply #9 on: 12 December 2011, 14:03 »
It was the hose with the braided bit wrapped around it which goes to the tiny nipple things under the manifold ...... Luckily there was a auq manifold local and the scrappy kindly let me take it for free aslong as i fixed there alarm, 2 fuses and a new battery 5 mins of my time for being heavy handed in the first place lol so not to bad now ive just got to re polish this 1 but its seriously pooped so i might get some one to do it. Cheers for your help though people !!
