Author Topic: bad sound maybe wheel bearing  (Read 1350 times)
Offline stig3105
« on: 12 December 2011, 01:06 »
just got a mk4 golf turbo its ok when you power on but when you let of throtle it makes a bad grinding sound .sounds to be on the near side
thanks for any help
Offline Steve_PD
Re: bad sound maybe wheel bearing
« Reply #1 on: 12 December 2011, 09:15 »
Does the sound get louder when going around a corner?
Offline harlemex
« Reply #2 on: 12 December 2011, 14:59 »
could be ineer cv.
Offline stevelfc
« Reply #3 on: 12 December 2011, 20:21 »
jack up one wheel at a time spin it to  see if you can hear any grinding noise and check for play in the wheel  shake wheel side to side and top to bottom
Offline stig3105
« Reply #4 on: 14 December 2011, 22:02 »
thanks for the help i jacked it up on the near side f/wheel it was that looked like the wheel was comming off it was the wheel bearing and it nakerd the hub
scord it in side
it was strange no sound when power on only when you let off the throttle
« Last Edit: 14 December 2011, 22:26 by stig3105 »
Offline richw911
« Reply #5 on: 14 December 2011, 22:21 »
thanks for the help i jacked it up on the near side f/wheel it was that looked like the wheel was comming off and it nakerd the hub
 :huh: What knackered the hub?
Offline stig3105
« Reply #6 on: 14 December 2011, 22:27 »
sorry edited it ,wheel bearing :embarassed:
Offline richw911
« Reply #7 on: 14 December 2011, 22:30 »
At least you know what it was  :wink:
