Author Topic: Gttdi flywheel  (Read 1477 times)
Offline barachello
Gttdi flywheel
« on: 11 December 2011, 21:53 »
The flywheel on my 99 gt tdi AHF engine has started making a clattering noise when the car is started. Apart from that it drives fine and no other problems.
I have been told that it is cheaper and better to replace it with a g60 flywheel.
Can anyone confirm this and any other advice appreciated
Thanks
Offline dvvid1993
Re: Gttdi flywheel
« Reply #1 on: 12 December 2011, 19:02 »
if the flywheel is a duelmass DONT relace it with a solid flywheel, it sounds like a good money saving idea and will all be well before you snap your crank, we have had to fix 3 cars that this has happened to. the manufacturers spend millions on these designs id stick to them unless your car is highly modified.
Re: Gttdi flywheel
« Reply #2 on: 16 December 2011, 21:03 »
You can get a solid replacment and they are fine to use however on a diesel your better to run a DMF
Offline danny_p
Re: Gttdi flywheel
« Reply #3 on: 17 December 2011, 19:14 »
IMO DMF  is not required on petrol,  but when you look at the rpm a high boost diesel makes it's power they really do need to be dual mass or much heavyer
all the VW's have gone bar 1.
