Author Topic: vr6 and vr6 highline  (Read 3269 times)
Offline jasonpi
« on: 10 May 2005, 11:00 »
ok as the title suggests whats the differences between the two
jay
Offline Overseer
Re: vr6 and vr6 highline
« Reply #1 on: 10 May 2005, 11:06 »
i beieve its a trim level thing..
highlines = metallics like purple etc..
also i believe all highlines came in leather..
not sure if air-con/climatronic is also a factor in this
Offline jasonpi
« Reply #2 on: 10 May 2005, 11:08 »
cheers thinking about getting one but dont know if a couple grand more as highlines are are worth it when its just a trim thing
Offline Overseer
« Reply #3 on: 10 May 2005, 11:10 »
are they really fetching that much more?
found this here >> http://www.beedubs.co.uk/default.asp?location=default.asp&id=13
"More important though was the Highline from April 1995. Manual air conditioning, leather trim, walnut topped gearlever, heated seats and either Black Pearl, or Purple Violet Pearl metallic paintwork which the hide would match. Both the standard and Highline VR6 were discontinued in November 1997."
basically the exact same spec as my valver apart from the walnut topped gearlever..
not even climatronic.. although i'd suspect people might opt for that.. if you're lucky
Veedubgt18v
« Reply #4 on: 10 May 2005, 20:51 »
think the highline is actually 2.9 whereas the other is 'just' 2.8 litres. highline has more power then i guess.
mix
« Reply #5 on: 10 May 2005, 20:54 »
Thats worth a couple of grand........ unless it was made from prehistoric rare wood..... :huh: :huh:
Veedubgt18v
« Reply #6 on: 10 May 2005, 21:31 »
with an extra bling coating or 24carat gold :HUH:
Offline piggy
  • What you lookin' at sonny?
« Reply #7 on: 10 May 2005, 21:40 »
I think that some of the plastic on the inside of the door pillars are a different colour, but there are a number of VR6s with most of the important bits like allround leather air con etc.
Also the V5 should show it as being a Highline.
They are worth more, normally because of all the extras, but against a normal VR6 with all the same extras it becomes a bit like having a mk2 16v or a mk2 16v conversion.
They are the same, but one will always be worth more than the other ( if the conditions are the same ) :rolleyes:
Offline jte
« Reply #8 on: 11 May 2005, 09:00 »
Highlines are 2.8 with no extra power.
There are a few differences, mainly trim.
Black interior A B and C pillars, Plastic sill cover with VR6 on it,  slightly different centre console and rear ash tray, VR6 badges with silver writing on a black background front and back.  All very pedantic really and not worth extra money.
Colour coded heated leather and Manual A/C is standard, climatronic was an option as with any MK3.
Highlines have 15" 6 spoke BBS solitude wheels the same as colour concepts and coraddo storms.
No real reason why a Highline should be worth more than a Normal VR6 with full spec, unless you desperately want purple Violet pearl metalic as a colour, which was exclusive to highlines.
I don't think highlines go for a couple of grand more than a normal VR6 but maybe a few hundred.
I say go for the best condition VR6 you can find.
A VR6 isn't a way of life, it's just a car.
Offline AudiA8Quattro
« Reply #9 on: 11 May 2005, 09:33 »
jte is spot on.... :wink:
