Author Topic: dials and asr button  (Read 699 times)
Offline ReadieeVTS
« on: 11 December 2011, 19:04 »
Hey guys my 1.8T (T reg) is fitted with the earlier still clocks, is it possible for me to fit the later ones with the MPG, temp etc in the middle?
also my car has no traction control button/switch, am i likely to have everything there so i can just plug the switch in?
regards Lee
Offline richw911
Re: dials and asr button
« Reply #1 on: 11 December 2011, 19:11 »
"My car doesn't have a multi function display, can I fit a set of clock with the display?
Yes you can but you will need a new wiper stalk (4B0 953 503 H) with the computer controls on it and then it will need wiring into the green multi plug connector on the rear of the rear of the clocks. Also if you currently don't have the outside temperature probe that is located in the bumper you will need to install one and wire it back to the green connector (pin 26) for the cluster to display the outside temperature."
http://uk-mkivs.net/forums/t/167146.aspx
