Author Topic: Sticky gearchange help needed  (Read 1177 times)
Offline SMcNairn
« on: 10 December 2011, 19:25 »
My mk4 now has a sticky gear change. It no longer springs back to neutral when required. This makes selecting gears more tricky as going from 2nd to 3rd is no longer just as simple. Also coming out of reverse, and selecting 1st, you have to make sure that you are no longer still in 1st.
Looked back over many pages of topics but havnt seen anyone else ask about such a problem.
Any ideas whats causing this?
Offline AD1.8T
Re: Sticky gearchange help needed
« Reply #1 on: 10 December 2011, 21:19 »
I think i have the same problem .... Every now and then if i reverse i then cant take it out of reverse unless i switch off engine take foot off clutch and pull it out ??? Clutch release bearing on its way out maybe ???
jamie16v
« Reply #2 on: 10 December 2011, 22:58 »
Offline SMcNairn
« Reply #3 on: 11 December 2011, 09:40 »
There must be a spring sticking somewhere . Its a weird feeling when the gear stick does not spring back to a neutral position.
Offline ben gttdi
« Reply #4 on: 11 December 2011, 09:56 »
Offline SMcNairn
« Reply #5 on: 12 December 2011, 08:04 »
Not been near the car this weekend. Will get on to it asap
