Author Topic: Mk 4 1.8 20v supercharged?  (Read 2302 times)
Offline dvvid1993
« on: 10 December 2011, 19:20 »
Hey. im new to this forum and i think im poting this in the right place, i wanted to do sommeting diffrent and have decided supercharging my 1.8 20v is what i want to do, i see very little anyware on the internet about this and was wondering if anyone had done it before and if so anything i should know?
Offline danny_p
Re: Mk 4 1.8 20v supercharged?
« Reply #1 on: 11 December 2011, 00:47 »
it's doable and been done,   seen it done with a G60 unit and various eatons.
the 1.8 NA 20v isn't worth converting to take boost because you can buy a 1.8T for less money and fit that, so then your buildng what you can buy and thats not good.
so you buy a 1.8T  and while sat there unbolting the turbo you should aks this question,  why am i unbolting  a turbo to spend a load of cash fitting  a ( in the g60 case ) an old supercharger that less reliable and will problay need an expensive rebuild  just to make less power than it would have done with the turbo.
or in the eaton case you can if you can be arsed to make all the brackets fit a really big one and make lots of power and torques but eatons are very good at killing engines and gearboxes,  they puff harder at the lower revs so you can drive on the torque in high gears  at low speeds and it'll pull but that gives the motor and transmition a hideing
all the VW's have gone bar 1.
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 11 December 2011, 01:01 »
agree with all of the above
really wouldn't bother unless you're committed enough to do something that sounds like and goes like this..
http://www.youtube.com/watch?v=Oj2J_pdqOk4
