Author Topic: loose bolts (Update)  (Read 3920 times)
Offline cullygti
« on: 10 December 2011, 12:45 »
heard a strange noise on the car yesterday as if the wheel was coming off so got home very slowly as didnt know what was going on and didnt like the noise on closer inspection 2 of my wheel bolts fell on the floor and the other 3 were all very loose im using standard bolts with 5mm spacers as im really low on coilies could i get away with taking the spacers off and still use the car or will they catch it as really put me off them now and im going to get 10mm hubcentric ones as they come with the longer bolts really  shocked me all the bolts being loose like that and the one was a locker bolt to cheers guys
« Last Edit: 13 December 2011, 16:39 by cullygti »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: loose bolts
« Reply #1 on: 10 December 2011, 12:48 »
I have never had my bolts come loose and I run standard bolts with 5mm spacers
Offline cullygti
Re: loose bolts
« Reply #2 on: 10 December 2011, 12:50 »
yeah i fort it would be ok to wes as done all the research before hand so am a bit worried now mate
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: loose bolts
« Reply #3 on: 10 December 2011, 12:55 »
Who did them up last and were they done with a torque wrench or just a bar?
Offline Steve_PD
Re: loose bolts
« Reply #4 on: 10 December 2011, 12:55 »
Get some longer bolts, the standard bolts with 5mm spacers only go in a few turns. Also re-torque the bolts after 50 miles or so
Offline harlemex
Re: loose bolts
« Reply #5 on: 10 December 2011, 12:57 »
Anything over 3mm should ideally use longer bolts.(just to be on safe side)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: loose bolts
« Reply #6 on: 10 December 2011, 13:01 »
Offline cullygti
Re: loose bolts
« Reply #7 on: 10 December 2011, 13:03 »
garage did them up when they fitted coilies im just gonna get new bolts or new spacers with bolts coilie on same side av developed a strange noise to so going to get them inspected on tuesday and they were done up with a bar and not torqued
Offline Dave_IOW
Re: loose bolts
« Reply #8 on: 10 December 2011, 13:08 »
I had a wheel come off after i forgot to properly tighten mine, and also had the same as you just last week.
Lost two bolts that i found back up the road, and three bolts that were loose in the wheel ready to come out, nearly three wheeled it again  :smiley:
These were both due to the bolts not being tightened properly, not because they are too short  :laugh:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline cullygti
Re: loose bolts
« Reply #9 on: 10 December 2011, 13:12 »
cheers dave could be the garages fault then as they were the last ones to touch them if im honest its made me a bit weary of using the spacers at all now
