Golf mk2
uneven idle
Topic: uneven idle (Read 1223 times)
hockeylad72
Here all the time
uneven idle
09 May 2005, 22:49 »
more help required
when car is at normal temp idle jumps about between 800 -1500 RPM then levels off after around 30 seconds have checked all vacuum hoses and they are all ok, was thinking it may be ISV?? is it possible to clean it (if it can be cleaned any tips for doing it) or do you need to replace part?
88 golf 8v pb engine code digifant injection
any help would be appreciated
cheers
Davie
...joe
Forum Supporter
Forum addict
Re: uneven idle
09 May 2005, 22:56 »
could be isv, apparently the best way to clean them is to stick it in a thing of petrol and let it run. or it could be sh!tty stuff in your throttle body. thats the only thing thats given me a rough idle, well, that and a lairy cam!
check your crankcase breather as these degrade overtime and oil and other sh!t gets into the isv and then on into the inlet manifold.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Veedubgt18v
Guest
Re: uneven idle
09 May 2005, 23:58 »
the crankcase breather can also get blocked with mayo like crap also check the pleated hoso for splits
solarized
Re: uneven idle
10 May 2005, 17:44 »
Same thing with mine, it's same engine as yours. Got meself a timing light, and checked timing as per Haynes manual. Found timing to be slightly out, adjusted accordingly, and hey presto - idles spot on now.
Veedubgt18v
Guest
Re: uneven idle
11 May 2005, 10:18 »
dont forget when doing timing disconnect the blue temp sender and time it of the flywheel at 2500 rpm after you have revved the engine over 3000rpm 3 times to clear the ecu
Golf mk2
uneven idle
