Author Topic: oil temperature  (Read 1767 times)
Offline the_GTI_new_guy
oil temperature
« on: 09 May 2005, 20:20 »
what temp should the oil gauge show at when normal temperature? What temperature would be "hot"? cheers
Offline Chris619
Re: oil temperature
« Reply #1 on: 09 May 2005, 21:38 »
Mines normally around  90 - 105
Offline hockeylad72
Re: oil temperature
« Reply #2 on: 09 May 2005, 21:53 »
mine is usually 86 - 96
if giving it some seen it as high as 120
Offline takethefifth
Re: oil temperature
« Reply #3 on: 09 May 2005, 22:27 »
Once warmed up can almost be guaranteed to be 94.
Goes up a bit if i give it some gas.....  :laugh:
Veedubgt18v
Re: oil temperature
« Reply #4 on: 10 May 2005, 00:02 »
mine is between 86 highest i have ever seen mine is 102
Offline Gambit
Re: oil temperature
« Reply #5 on: 10 May 2005, 10:20 »
for a 16v 88 - 110.
ive seen it as high as 122 on my old 16v, supposedly if it gets up round the 146 mark this is when you start to panic
Offline tinman
Re: oil temperature
« Reply #6 on: 10 May 2005, 10:47 »
^ wot he says.
usual temp used to be around 95 however my rebuilt golf is showing an average of 80 which is definitely too low.
highest i've ever seen on a particulary "interesting section of road" before the rebuild was 126. i have seen higher though when the car had a big overheating problem. panic isnt the right word ;-)
Veedubgt18v
Re: oil temperature
« Reply #7 on: 11 May 2005, 10:23 »
yeah pant fill is more accurate!
i think mine is to low gonna put a new thermostat in cos i reckons its stuck open slighlty
