Author Topic: 1.8T AGU Poor acceleration / hesitant - 00515 Fault  (Read 5888 times)
Offline Simpson GTI
« on: 08 December 2011, 14:20 »
Recently I've had a problem where my 99 GTI AGU has been sluggish on acceleration. It idles smoothly and revs cleanly from stationary, but just feels sluggish through the revs and slightly hesitant (almost stop / start) when driving.  :embarassed:
On running a diagnostic check the code 00515 comes up which seems to relate to one of two Cam Hall Sensor G40 errors. If i clear the code with the ignition off then it doesnt return until the engine is started, but with the engine running it returns straight away.
When starting the engine, it takes a moment or two longer to start, hot or cold, whereas before it just started on the button. Could a faulty sensor cause this symptom?
It's had a recent oil change and i've cleaned the MAF with alcohol and that's throwing up no codes. Also fuel consumption seems ok.
I changed the CAM Position Sensor albeit for another used item which seemed to fix the problem for a day or so even though the code never went away. The wiring loom to the sensor looks ok and am getting voltage down the wires.
Anyone with any ideas before i buy a new sensor or take it to a garage?
Cheers  :smiley:
Offline topher
  • Administrator
  • fully functioning
Re: 1.8T AGU Poor acceleration / hesitant - 00515 Fault
« Reply #1 on: 09 December 2011, 17:17 »
if its not the sensor or a wiring issue, it could be that your cam timing chain has stretched/skipped or an ECU fault.
Offline Ant1981
  • Feed me, prod me
« Reply #2 on: 09 December 2011, 17:25 »
Usually the ignition needs to be on to read and clear codes. So if you've still got the same code, try again with the ignition on.
'09 Kawasaki Ninja ZX-6R
Offline Simpson GTI
« Reply #3 on: 10 December 2011, 17:49 »
Thanks for the info, i'll get wiring checked first and then look at timing etc.
Cheers  :smiley:
Offline Simpson GTI
« Reply #4 on: 14 July 2012, 00:01 »
Just to update in case anyone else experiences this problem, buying a brand new Camshaft sensor fixed this straight away. The car starts fine and pulls strongly. Cheers
Offline wolfie1981
« Reply #5 on: 02 August 2012, 16:54 »
ive had this code show up today car seems fine no loss of power ect/ect .
my prob is this when i did the first scan the code 00515 came up on my scanner done it again 20 mins later no codes???
any idea's???
