Author Topic: sh!t-shaped utility motoring  (Read 187179 times)
Offline VR6_Wherry
Re: Chuff says I should start a thread for this POS
« Reply #100 on: 13 December 2011, 13:35 »
Chuff, just don't upset DH or he will just leave it on your drive!  :grin:
Offline Diamond Hell
  • Opinions я Us
« Reply #101 on: 13 December 2011, 22:01 »
Will I bollox - I need something to get me about!
Today's modification: replacement wiper blades, the posh ones with the little spoiler thing on the drivers side.
That's shut the bloody juddering up.
Also changed the stereo illumination to match the serene green of the dashboard.  The light on the clock is out, which is slightly tiresome, as it's not terribly visible in the dark.  I suspect it will remain that way though....
It's also taken the stereo out a couple of times when starting from cold.  I suspect this is because it has a smaller-than-it-should-be battery on it: the stereo comes on with the ignition, while the glowplugs warm things up, then when I crank it, I suspect the voltage drops WAY down and the stereo gives me the finger.  Won't come back on unless I hook it out the dash and pull the power.  :angry:
I think the 167k engine and gearbox mounts are probably responsible for the slightly queasy feeling resonance that comes through the car at low revs in fifth.  Annoying if you're having a pop at hyper-miling.... but that's not really my style.
i would have a mk3 syncro but only seem to be on continent
Indeed.
There's a total of 20 TDI Syncro Golfs on mobile.de at the moment.
Here's something to tempt Danny Monday: http://bit.ly/v8RuW1
And this would be good, but only for the shell, which would need stripping out and caging etc etc etc: http://bit.ly/sVg1Wu
Although that last one's in Poland - I suspect there wasn't a 3-door Syncro G3 made, but someone in Poland decided there should be, so got the grinder and welder out.  :grin:
Offline Bellend
« Reply #102 on: 13 December 2011, 23:09 »
If you need a bulb for the clock PM me your address.
You'll have it changed in exchange for ten minutes of your time.
Where all my moneys went.
  • Opinions я Us
« Reply #103 on: 13 December 2011, 23:41 »
I don't.  The clock is fine as it is.
Offline SoundillusioN
« Reply #104 on: 14 December 2011, 00:06 »
No THANK YOU.  If I was really that bothered about it I'd be able to get one myself.
 :rolleyes:
Offline JC
  • Back in the North.
« Reply #105 on: 14 December 2011, 07:18 »
anyone would think it was a fcukin syncro the way you drive it  :lipsrsealed:
 :grin:
but in fairness for what you paid for it, it is ideal :afro:
and when it rots out cos you keep taking it on a ferry, the corrado diesel idea is tops  :shocked: :lipsrsealed:
« Reply #106 on: 14 December 2011, 09:19 »
 :grin:
 :sick: Well, depends on the motor.
  • Opinions я Us
« Reply #107 on: 14 December 2011, 11:04 »
:rolleyes:
I specifically stated I would not be replacing the bulb.
With greater comprehension comes someone who might be bothered to be polite.  :tongue:
Just like telemarketers offering me something I've stated I don't want.  Don't call, don't get abused.
« Reply #108 on: 14 December 2011, 11:38 »
^^^ Fair enough.  Although....
... doesn't seem like a specific statement, more like a suspicion of your own bone-idleness to fix it.  :grin:
  • Opinions я Us
« Reply #109 on: 14 December 2011, 11:44 »
Will a lit clock make it drive any better?  No.  It's not bone idle, it's a specific focus.
Rubbish - I was being nice and it has good tyres on it - and drives straight.
More likely to end up in a T25, like that POS Polizei bus still cluttering up my workshop.
Rather tiresomely it seems quite rot-free, except behind the NS front wheel, where I suspect it has had a tap at some point and some filler and shyte gobbed into it.
