Author Topic: what camshaft is this?  (Read 2239 times)
Offline bearproof dave
« on: 07 December 2011, 18:04 »
the cam has the following numbers engraved-
026
W20
2351
the pulley that was attached has the following numbers-
049 109 111 B
SSF
hoping its from a mk2 gti digi and will be suitable for my f reg 1.8 GL which i am assuming has hydraulic tappets?
cheers, dave
Offline Sam
  • Sam I am
Re: what camshaft is this?
« Reply #1 on: 07 December 2011, 20:01 »
The pully number seems to be a generic mk2/3 44t pully. As for the shaft... no idea  :laugh:
« Reply #2 on: 07 December 2011, 23:25 »
cheers for the reply matey
hopefully someone else will shed some light on the cam
Offline Sam
  • Sam I am
« Reply #3 on: 08 December 2011, 00:29 »
I did drag up a load of details on the cam from kent cams or somthing but then I lost it all!  :lipsrsealed:
« Reply #4 on: 08 December 2011, 17:06 »
bugger!
cheers for your efforts though bud
Offline Sam
  • Sam I am
« Reply #5 on: 08 December 2011, 17:23 »
There must be some more numbers on the shaft no?
« Reply #6 on: 09 December 2011, 23:56 »
not had a chance to check for more numbers yet, however i have just seen a mk3 gti cam on ebay and the part number stated is
049 109 111C
the number on mine is 049 109 111B
im thinking mine could indeed be a late gti cam?
« Reply #7 on: 10 December 2011, 00:06 »
ignore that last post, just realised my mistake
Offline Sam
  • Sam I am
« Reply #8 on: 12 December 2011, 20:08 »
From what I can figure out, A and B go together on a DOHC and C is a single cam. This doesn't actually confirm anything, thats if its even correct but It would indicate that the cam you have is from an 8v
« Reply #9 on: 12 December 2011, 22:15 »
i read somewhere that a hydraulic cam base circle should measure 34mm. not sure if that applies to gti or standard though?
not sure exactly what the cam base circle is meant to be. i measured it up today and found that the lobes measure 34mm accross the width.
whats reckon?
im thinking of fitting it anyway and seeing what happens? once ive got the 2 cams side by side i should be able to see if one is noticably different?
