Author Topic: Temperature Gauge  (Read 3090 times)
Offline GTI16vGaz
  • New car will be displayed soon.
Temperature Gauge
« on: 22 September 2003, 19:51 »
Does any1 know where abouts my temperature gauge is connected in the engine or where abouts i could locate it.
It only works when it wants to.. it would be ideal if it was working all the time.
My car is GOLF GTI mk2 1989 3 door.
Its the gauge in the middle of the clocks a bit to wards the top, i hope makes sense.  :-\
Any help would be great.  ;)
Gaz
golfvr6
Re:Temperature Gauge
« Reply #1 on: 22 September 2003, 23:58 »
I think that works off the coolant temperature sensor which i think is mounted on the elbow coming out of the cylinder head.
Offline Gambit
« Reply #2 on: 23 September 2003, 14:02 »
16v's are on the outlet elbow
8v's are somewhere else, and i cant remember where - ill look into it
Offline GTI16vGaz
« Reply #3 on: 23 September 2003, 18:52 »
cheers lads  ;D
golfvr6
« Reply #4 on: 23 September 2003, 18:57 »
When you do find it earth it to the engine with a paperclip and the gauge should read maximum, This will tell you that the gauge works ok.
« Last Edit: 23 September 2003, 18:57 by golfvr6 »
Offline Gambit
« Reply #5 on: 24 September 2003, 14:03 »
for an 8v the water temp sensor/sender in on the outlet elbow on the front of the block
there is two senders there, one with a black wire & one with a blue wire
u want the one with the black wire going to it
Offline GTI16vGaz
« Reply #6 on: 24 September 2003, 14:26 »
Thats great  ;D thanks!
I'll start cleaning the connectors and hopefully it sould be the connector that is covered in dirt that needs removing to enable the temp gauge to work again, the problem is really intermittent.
thanks agian  ;)
Garry
Offline GTI16vGaz
« Reply #7 on: 03 October 2003, 19:47 »
Thanks for the information, however i had a good luck and all the wires have 2 different colours.. does this sound right?
Thanks ;)
